1 - 4 of 4 Posts
I've searched the forums and the interwebz and can't find a conclusive answer. Any help?
My rear passenger door won't trigger the interior light. If I open it, the light doesn't come on. It acts as if the door is closed. Thoughts? Ideas? Suggestions?
Thanks.
Premium Member
The sensor is in the door lock actuator/latch assembly. You need to replace it. Don't bother spraying with silicone lube or WD-40 as suggested in some other threads on the subject. It won't help. Here is a web page with all the part numbers for a new assembly along with links to replacement instructions. http://www.bmwgm5.com/E46_actuator.htm
1 - 4 of 4 Posts
