The door locks only work intermittently on my M3. It will lock then refuses to open. The key mechanism has been removed as a security feature which leaves me locked out. I can remotely open the windows but the inside handle won’t open the door either. Both sides are the same. The drivers door latch has been replaced and was working fine. I can sometimes grip the inside button with pliers and pull it up which enables the opening of the door with the key fob. Even then the drivers door remains locked. Everything else works and I can drive the car. Sometimes when I then stop, everything will work fine but other times the door remains locked. When I try and open the doors with the key fob, the locks just click as if stuck and will activate in the door really slowly as if something is flat. Even then the locks fail to open. At the moment I daren’t lock the car. The boot still works fine. WTF, any ideas.
