1 - 2 of 2 Posts
E46 325i 2001
Centre console door lock switch doesn't work when the car is off or the key is in the accessory or on position. It only works when the car is running.
Is this normal, if so how do you unlock the doors from the inside without the key?
Premium Member
Not normal. If I unlock my car with the key fob I can control the locks with the center console lock and switch no problem with and without the key in the ignition with and without the car engine running. Maybe if there's a problem with the driver side door latch she doesn't realize that the doors open?
1 - 2 of 2 Posts
