1 - 10 of 10 Posts
hey everyone,
this morning i look at both my front doors and i realize that the airbag section on the doors is unsticking? its like there is a big airbubble inside of it?
Below is the part i mean, but, how can i fix that? do i have to dismantle the door?
thanks everyone
btw: that is not my door..just to show you the specific part.
You'll probably have to do some minor surgery (guessing) to get between that leather surface layer and the foam beneath it. Then use some like spray fabric/upholstery adhesive to get that "bubble" out.
Isn't that piece usually just replaceable?
is there a way to remove it?
When I took apart my door trim, it did not seem that it was possible to remove. It looked as if it was held in very tightly by either clips or an easily breakable plastic seam. I didn't try to take it apart, but it looked to be a pretty solid piece.
This is why airbag covers suck :( They warp, they come apart, and are unsightly. I'm glad technology improved to hide them in the dash and door frames on new cars. I don't know why it took BMW so long to build the covers into the dash with their current lineup.
It is easily removable, unless they changed something between my year and your year. I've had my entire door panel taken apart multiple times.
1 - 10 of 10 Posts
