What do you think?
  • Got 18\'s but wish they were 19\'s
    Votes: 6 27.3%
  • Got 19\'s but wish they were 18\'s
    Votes: 2 9.1%
  • Got 18\'s and love them!
    Votes: 8 36.4%
  • Got 19\'s and love them!
    Votes: 6 27.3%
1 - 16 of 16 Posts
I know there is always a ton of debate between 18's and 19's.
Does anyone that got 18's reget it?
Does anyone that got 19's regret it?
Imported *******
19s here, and haven't noticed too much of a difference in how the 330 drives....just about the same.
Suck it easy.............
I got 18's first...and then regretted not gettin 19's like a couple of weeks later.....thats why my advice would be to just go with 19's to start with...:thumbup:
Yup yup...same here :) Def just go with 19's first...you will regret it!!
Kleemann Info Centre GmBH
Same with the other guys first got 18"s then for some reason 19"s was just callin my name! :lmao:
Senior Eurowerkz Member
love my 18"for the reason
lov to drive fast with at 18". helps alot if you hit a hole going fast, if you had 19" maybe you will bend the rims. 18" gives you a little more of a cushion with the holes of bklyn. a little trick to, his to put the air on the high side to make tire a little harder. helps big time with the holes makes tire harder to get to the rims.
bobm3 ;) ;)
i wish i had 22's or 20"s. Then i'd be baller
Discussion Starter · #15 ·
Well it seems that quite a few people are very happy with there 18"s almost as many as 19"s.
Cybertek, def go with 19s, unless you drive through bus 17 a lot...potholes are a dime a dozen there...just drive speed limit and you should be okay. I'm shooting for 19s, I contemplated 18s, but a bunch of ppl say 18s are just as easy to bend as 19s. Besides, they definitely look way better...:thumbup:
1 - 16 of 16 Posts
