1 - 9 of 9 Posts
I am looking to run four pipes out the back of my car and wonder if a M3 bumper can be fitted on my car?
Legendary like a schoolboy
the front fit with minor adjustments, the rear will too but will look very awkward since it not going to line up with the rear quarter panel. Plus to bust a four exhaust, your gonna have to cut through the spare tire wheel well. GL
A bimmer chick moderator :)
^ :werd: u need to retrofit it, not only do you need to cut out your spare you need to raise your battery up
Frankie Y said:
how much would those slight modifications/custom setup cost on top of the bumper itself?
a buttload.
these are NOT slight modifications. cutting out your rear tyre well, welding in metal, cutting out your battery and fabricating a new brace for it, as well as modifying your trunk carpet to accomidate less space
if you are not extremely rich or ambitious i would leave well enough alone.
btw aftermarket m3 muffler alone is going to cost upwards of 1200 baseline. all the way up to kreissig (lots)
1 - 9 of 9 Posts
