My tire shop balanced the wheel/tires. I have little weights on my wheels.SteelBlueXI said:Find a perfectly flat, perfectly smooth road. Get it up to 40 or 50 going perfectly straight and release the wheel. If it still pulls, it's radial tire pull. If it doesn't, you're just not used to tramlining. Your tires are a lot stickier and bigger now. And your bigger tires have a much shorter track because YOU PLUS SIZED 3 INCHES!!!
But to answer your question, if your new wheels have a similar offset and you bought tires with a similar circumference to your old ones, you should not need an alignment.
A good road in Westchester? Ha! :spit: My car is falling apart from all the potholes.PLAZAMAN said:My tire shop balanced the wheel/tires. I have little weights on my wheels.
Thanks guys i'll check this out.
Steelblue, why dont u tell me a good road since your in westchester, heh.
im in NYC, but goto school on central ave.
SteelBlueXI said:A good road in Westchester? Ha! :spit: My car is falling apart from all the potholes.
I guess your best bet would be to try I-87 southbound south of 287. :dunno:
Where do you go to school? I assume WBI if it's on Central Ave? If that's the case, you're like a mile from where I live.
You should come to our Westchester BBQ in a few weeks. See the events section.
Cool, I live just off of North Broadway in White Plains between 287 and the Westchester mall. I'll keep my eyes peeled for the 325 with 19" Visions on it.PLAZAMAN said:Yep, WBI. My car is usually parked in front of the school. I'll try that road ....
I might come to the BBQ if im around!
PLAZAMAN said:I recently changed my stock 16s to 19s.
Now my car pulls to the right.
no suspension changes
help.. i dont want 2 wear my tires out
