1 - 12 of 12 Posts
i am running 19X8 with 44mm offset..........235/35/19 pirelli P7000
and i want to push my wheels out a little bit more in the back with a spacer ..........do u think 10 mm is too much??
Wide Ass on 20's
You can fit a 15mm spacer on a 19x8.5 wheel with +44 offset. If you do that, you will have to roll the rears
With a 19x8, you have an extra .5 inch so that is about 12.5mm
10mm is no problem.. you can even run 15mm and it should not rub
19x8 and 19x8.5 makes a difference
call me kev :D
that makes your offset 34mm, you should be fine, i wouldn't go 15mm spacer tho.. might be a bit aggressive.
10 should work without fender rolling.
Wide Ass on 20's
10-15mm on an 8 with +44 will look fine
Its up to you how aggressive you want your offset
Ditto what BlueE46 said.. plus dont forget you will need longer bolts to allow for the spacer thickness too..
remember 5 mm is roughly 3/8" wider.. do you think you will be able to tell that much difference if you only use on the rear?
Discussion Starter · #6 ·
oops ......typo i have 40mm offset not 44..........would that make a difference then??.........and where do i get longer bolts?
Wide Ass on 20's
Yes that does make a difference.
Make sure its in fact a x8 rim and not a x8.5
Usually 8.5 width rims run 235 rubber
Wide Ass on 20's
hamann 330Ci said:
yeah i am running 235 tires
I said check RIM WIDTH... not tire size
Rim width and offset is the most important factor
Rubber size, brand and sidewall shape is only important if you want to slam it and are going to use the ABSOLUTE MAXIMUM offset where every 0.1mm counts
1 - 12 of 12 Posts
