101 - 116 of 116 Posts
Just wanted to let you guys know that my engine blew on my 330 smg in December. This was after I replaced my seal and it was working flawlessly. After I swap the interior and rims and brakes on my other e46, ill be parting out whatever anyone wants. If anyone needs any specific smg parts shoot me a pm.
Wholly crap, Very sorry. What the heck happened?
Hi guys,
I bought e46 330ci SSG 5-speed. I had to change clutch and dmf. during the cluch replacement I had notice, that my slave cylinder is bleeding.
Here is what I did:
1. I ordered #21521159332 (from local dealer 51 ***8364; - $57).
2. Then I removed the slave cylinder (on 5-speed transmission it's not that easy, I had to remove: transmission support cross, protection plate, hydraulic pump, expansion tank, hydraulic line to slave cylinder, than at last slave cylinder)
3. Than I visited a seal maker, he made for me a main piston seal 12x20x5,5 FKM and two seals for expansion tank (expansion cap cover and where the hydraulic pump is connected with expansion tank - FKM of course). (6 ***8364; - $7)
4. Filled with new hydraulic oil (10 ***8364; - $11)
5. INPA - bleeding the clutch
6. Check for expansion tank, filled to "max"
Maybe this can help someone in the future :)
Thanks for this topic, very helpful!
Works great :thumbup:
Hi guys,
Here is what I did:
1. I ordered #21521159332 (from local dealer 51 € - $57).
3. Than I visited a seal maker, he made for me a main piston seal 12x20x5,5 FKM and two seals for expansion tank (expansion cap cover and where the hydraulic pump is connected with expansion tank - FKM of course). (6 € - $7)
4. Filled with new hydraulic oil (10 € - $11)
I should find you the photo of the pool of hydraulic fluid left outside my house when this method can fail.
I am having some problems with my ssg system I have removed the actuator today and it's dry. I have looked at the resovior and identified the fill cap bit I can't see the min max lines can anyone point me in the right direction?
On my reservior this is considered full by BMW. I cannot recall fill lines, but I remember the CHF11s (dark fluid) being more than 3/4 of the tank. The system should not "use" any fluid at all.
Edit... Better picture. Yellow full line.
Thank you I will check.the level tomorrow. I don't think it has this much oil in. I have had the actuator out and this is dry despite the symptoms pointing to it.
Hi guys,
Here is what I did:
HI There, how's your seal replacement is it still working well?
I sold my car, but I stayed in touch with the new owner.
Last month I was talking to him and he told me, that it works great and the fluid level is good. :thumbsup:
Can I order just the piston seal from you since you easily make those at your place and FKM material is viton which is more reliable than the stock one.
[QUOTE = "thurston512, publicación: 17547721, miembro: 174488"]
Aquí hay algunas fotos del sello que estoy usando actualmente.
[/ CITAR]
Does the seal still work well with that measure?
I have to do the same job in my car.
Thanks a lot
[/ CITAR]
Thanks a lot
[/thurston512]
I'm glad this was helpful. Unfortunate about that shop you had to deal with. Let me know how this works out and if you have any questions.
BTW it's been 4+ months without any problems this summer in both heat and traffic. 👍
[EDIT:] Just wanted to update that as of Aug. 29, 2014 still no problems :)
what did you use to remove the new seal from the new piston?
