You do not need to remove your transmission or remove the bell housing for machining to convert your SMG car to a 6sp Manual… (HACK!)
Extremely abbreviated conversion:
1. Buy a self-centering shifter like one of the 2 listed below, RTD or CAE. You DO NOT NEED to weld or rivet anything under the car in the transmission tunnel to use this
or machine the bell housing or tap the transmission for the gear identification switch. Or remove the transmission at all!
2. Buy a manual slave cylinder 21526785966, 3rd pedal/assembly (various parts), selector rod 25112228711, gear selector rod coupler 25111222688, clutch master cylinder 21526773670, and clutch position sensor 61319122700, the lines off that to go to the slave (various parts), the pigtail harness (or clutch switch adapter lead) 61116911072, and you’re pretty much good. Utilize realoem.com and/or the M3forum’s thread for the little extra parts I didn’t list out. http://m3forum.net/m3forum/showthread.php?t=444126
3. Get a tuner to convert your DME from SMG to Manual, I used EPIC Motorsports out of Miami, Randy Mueller emailed me a file I just uploaded using the Engine Calibration Interface I have from my tune he did for me.
4. No more SMG! Sell parts removed to recoup some or all of your cost.
Extremely overly communicated conversion:
You also don’t need to wait for your pump to fail to plan this conversion! All you need is a self-centering shifter like the RTD Page Not Found » Home or get the very established CAE which you can get thru the very accomplished Spec E46 race Chad Morehead CAE Ultra Shifter - BMW E30 / E36 / E46 - Morehead Speed Works Both will solve needing to remove the transmission and machine the pins to define the travel of the shifter because the shifter itself defines top-dead-center for 3rd/4th gear and does all the controlling of the play for you. NO MACHING THE TRANSMISSION OR PULLING IT!!!!! *You certainly CAN pull the trans and that will give you more working room, a chance to change your clutch, flywheel if necessary, fork pivot (those can heat cycle out and go bad) throwout bearing, and rear main seal. You also don’t HAVE to tap the trans for the Gear Identification Switch to get the car running. It may impact cruise control and or the reverse lights. If you do drop the trans I recommend using a piece of cardboard to keep track of what bolts you pulled and their position so you know for re-installation. I used a IDPA target to keep track as I removed them. Very helpful to not worry about losing a bolt or wondering if you missed one etc.
My brief background is: I was going to dyno my car for the first time now that I got my EPIC Motorsports race tune and installed LinesRacing ebay headers. On the dyno a pop happened while getting ratcheted down and I proceeded to dyno 0whp as all the yellow dash lights on the right came one:
Because my slave cylinder rod’s delrin end had heat cycled out and gradually worn thru the fork and punctured thru and burst the seal inside the slave so all the hydraulic fluid bled out thru the slave down the bell housing and the fork briefly wore down the pressure plate.
So faced with pulling the transmission and replace the fork and slave (and maybe clutch if damaged, but was not needed) I decided now was the Manual conversion moment.
There’s the Ultimate SMG Conversion Thread from M3Forums http://m3forum.net/m3forum/showthread.php?t=444126 and that is super helpful but it lacked some details (for my personality type) that I will attempt to fill in as well as point out the good news: No removal of the Transmission or Machining the bellhousing is needed to convert!!!
So presuppositions: You have to know what you’re doing or have a really good friend who is to walk with you on this. Also have all the parts you need ahead of time to prevent multiple days with your car immobile (particularly since most of us do these over a weekend). Please feel free to look me up on facebook https://www.facebook.com/public/Mike-Sharrett and msg me and I will gladly help if I can. I’m Mike Sharrett currently living in Lynchburg, VA employed by the most badass Wall Street firm, Merrill Lynch, and I’ll likely have a profile pic of my son or me and my son and my wall pic will be my car on a racetrack or me doing a shooting competition. If you have access to a lift I recommend buying as much beer as necessary to let your friend use it and if there isn’t a transmission jack or tall tower jack consider buying those from Northern Tool a $200 total rental fee for your friend’s lift usage. I bought an engine brace too in this picture which wasn’t necessary for this job but helps when you do rod bears, oil pan gasket, motor mounts, anything that takes the front subframe off.
I did all my work on my lift in my garage but it is do-able on jack stands if you’re insanely patient. I also had to pull my trans because of the fork needing replacement.
With the car in the air remove the driver’s side front wheel. Under the car, drop the catback exhaust, and take off the drive shaft so you’ll be able to lower the transmission. Remove the skid/reinforcement plate too (16mm bolts). As for underpanels (remove any in the way), see other DIY for that because if you can’t figure that out, ABORT.
Remove the hydraulic line going into the slave cylinder with an 11mm wrench. Unscrew any brackets that hold hydraulic lines along the trans. Unplug all sensors to the trans and move them out of the way. Use a 5mm ( I think) allen wrench to remove the brackets or any hydraulic lines so you can get ready to rid your car of everything SMG.
Remove the airbox, intake box, associated breather tubes, smg reservoir fluid tube, everything to get to like you’re going to remove the starter. Don’t forget the really small breather tube under the intake box by like cylinder 4 or 5, you don’t want to break that.
I have reused my throttle body boot clips like 9 times so don’t worry about buying new ones if you can get them off using long pliers. Once your intake box is our remove the 4 lines from your SMG pump with an 11mm wrench. I used a grinder to thin the outer edges of the open end of my wrench to make it thinner and more nimble to undo the lines. Feel free to bend the air box bracket out of the way or remove it with a 13mm socket to get it out of the way. Work the lines from left to right, or passenger to driver side. Each one removed will allow more room for the next, and feel free to push them out of the way with force or zip tie them out of the way, there’s play in their length and the brackets that held them should be removed.
Once the 4 lines are removed, remove the 10mm bolt that holds the pump in it’s place that is under it, access from the driver’s side front wheel well (take that wheel off), and while you’re there unscrew the big (2” maybe? 1.5” at least) electronic wiring harness plug that goes to the pump, just unscrew until it separates, there’s a 12 oclock north hole in the bracket the pump-side plug sits in that will hold the other end in place.
