1 - 4 of 4 Posts
Reposting because I think the guys in the DIY thread might know a little bit more than in the General thread. :) I have a '00 E46 328CI that has the original LF-20 pump that just went on me, got a very good deal on an LF-30 power steering pump.. I also found this TSB bulletin (at the bottom), which makes it seem as if upgrading IS an option.
Has anyone had any experience upgrading to the LF-30? I scoured the Internet and found someone else who said "they upgraded" ... any thoughts? Do I just buy the NEW higher PSI hose and re-use the mounting brackets from the old pump, or am I going to have to custom fit the new LF-30?
http://www.bimmerfest.com/forums/showthread.php?t=213186&highlight=lf+30
http://www.bimmerfest.com/forums/showthread.php?t=337958
I know by physically looking, the mounting brackets and pressure hose look different, I just want to make sure if I can use the LF-30 pump before I sell it!! Thanks in advance!!
SUBJECT
LF-20 Power Steering Pump
ODEL
E46 (3 Series) equipped with LF-20 power steering pump, except All-wheel Drive Vehicles
SITUATION
Customer may complain of increased efforts to turn the steering wheel at low vehicle speeds, e.g. when cornering or parking.
CAUSE
LF-20 power steering pump may have internal drive shaft wear damage from fluid impurities.
CORRECTION
In case of a customer complaint, replace the LF-20 power steering pump with LF-30 power steering pump.
PROCEDURE
* Verify the LF-20 power steering pump part number used on the vehicle and refer to the Parts Information below for the appropriate LF-30 power steering pump replacement.
* Replace the power steering pump per Repair Instructions RA 32 41 061 or RA 32 41 060 (M52/M54).
* Also replace the pressure hose and o-ring.
PARTS INFORMATION
Part Number Description Quantity
32 41 1 094 965 LF-30 power steering pump replacement for LF-20 1
P/N 32 41 6 750 423 or 32 41 6 760 036
Or, 32 41 6 756 582 LF-30 power steering pump replacement for LF-20 1
P/N 32 41 6 760 034
32 41 6 764 725 Pressure Hose 1
64 50 1 468 463 O-Ring 1
Any help is greatly appreciated.
I did this only because my pump died on me, it'll work, I had to replace my supply and return hoses though, (one from the reservoir and one to the rack).
The LF-30 will replace your LF-20 with no problems, it just makes the wheel feel lighter and I guess it lasts longer...
Dang! old thread....
1 - 4 of 4 Posts
