1 - 4 of 4 Posts
Big in Japan
remove the plastic on either side of it, and twist the base from the windshield and it will come right off.
-and im still working on the autodim retrofit, waiting for damn parts!
It should take you about 10-15 min. Look at the mirror you have now and you can see the line between the two pieces of plastic. I used my fingers and nails and it popped off. When it does you will notice like a silver circle on the windshield and the mirror is attached to that. Twist the mirrors base towards the right(Passenger side) it will move up and then pop out. Also disconnect the wires and then plug it back in to the new mirror. When putting the new mirror in what you do is get it in place it will lock then twist it back down towards the drivers side and it will become secure and then put the cover back on and ur done.
1 - 4 of 4 Posts
