nice diy..
valkcampbell82, recommend you start a new post with your exact symptoms and what you have done so far, this DIY forum is very good but you will get more traffic in the General forum, lots of people willing to help but this is pretty vague, did the car start before you changed the sensor?ok i have replaced the sensor as u have shown and the car still wont start. if the fuses 15 an 30 are good can i unplug the sensor and the car run? other sites i have found say that if those fuses are good then the sensor plug is bad but the car will work without it, are they right. i need help ASAP
This may be a dumb question, but has anyone looked at their oil level sensor after replacing it to see if sludge or grime in their oil at the bottom of the oil pan there caused the malfunction, rather than an actual electrical problem inside the sensor?
Pelican has a DIY. http://www.pelicanparts.com/BMW/tec...Pan-Gasket/101-Projects-19-Oil-Pan-Gasket.htm (but it's more for the e36).Does anyone have a DIY on this--I need to replace my oil pan gasket too.
@hk_e46: I heard it is quite a PITA. I have read around that not only do you have to remove this, but also the front subframe. Some have been able to do it without removing this subframe but they do mention something about lifting the engine about an inch or two, which would require an engine support or cherry picker. I probably would not quite trust the engine support seeing how the weight of the engine is still kept on the car. It would be nice to have a DIY with pictures though.
