1 - 7 of 7 Posts
I was gonna do my oil change myself today, using the diy instructions from 330ci.com. But then I look under the car and noticed that it doesn't have an oil cover compartment.
Instead, I did see what looked to be a drain point. It had about 3 hex bolts holding a black circle cap closed. Is this where the oil is drained or is this where the transmission fluid is drained.
I didn't raise the car, I just turned the wheel to right, and could see and access the site in question.
I drive a 323i 99e46 so I wanted to be sure I didn't drain the wrong fluids? I should be able to change the oil without jacking the car up right? I'm a cheap bastage and don't wanna get a jack or lift.:eeps:
sedans don't have the compartment door...
no thats not it...from the passenger side just behind the front wheel...you should be able to see the drain bolt. 17mm i think.
Discussion Starter · #6 ·
umnitza .. jetblack.. thanks..I got it now.. The video was a big help.. Nice little website there.:pimpin:
Site Sponsor
danke:D
Actually, how do you describe it, proud and embarrassed. There is SOOOO much that I have to finish on that site, my list runs the lenth of my car in single space 4pt font:(
But, I will have HUGE info in the next three days:
we're doing an install fest that mpactmotorsports.com is sponsoring here locally.
There we will be removing bushings, installing suspensions, etc.
Not to mention the X-braces, HID installs, etc.
So, keep going back, I'll ahve a full video section soon:)
1 - 7 of 7 Posts
