1 - 4 of 4 Posts
Banned
I thought I would throw together a quick DIY for rebuilding the LUK LF-30 pump. If yours is intact, but leaking, this is a cheap route to getting the steering feel back.
Note. Inspect the shaft before rebuilding. If the shaft is broken, the pump should be replaced.
Parts:
Hose clamp
New seals:
Tools:
1. T30 driver or socket
2. 28mm socket
3. Pick and knife
4. 10mm and 13mm sockets
5. 17mm crows-foot
6. Container to capture waste fluid
7. ATF fluid
8. Replacement hose clamp for supply line
Tasks:
There is a great guide for removing and replacing the pump itself:BMW E46 Power Steering Pump Replacement - 1998-2006 3 Series
1. Loosen the pulley screws
2. Detach the serpentine belt (plenty of belt DIYs)
3. Detach the pressure line. Have the drain tray ready to capture the fluid.
4. Remove the supply line at the pump. Throw away the copper washers once removed. They are not reusable.
5. Remove two bolts on the front holding the mounting bracket to the oil filter housing
6. Remove the mounting bolt on the rear and remove the pump
Now the fun part!
7. On the bench, remove the four Torx screws holding the rear cover plate on the pump. Replacement torque - 54 in-lbs
Gas Nickel Font Rim Metal
8. Remove spring washer (center)
Remote control Automotive tire Camera accessory Bicycle part Rim
9. Remove and replace reservoir o-ring
Bicycle part Gas Machine Metal Camera accessory
10. Remove and replace outer seal on thrust plate
Bicycle part Rim Automotive tire Gear Motor vehicle
11. Remove and replace inner thrust plate seal
Bicycle part Gear Crankset Rim Bicycle drivetrain part
12. Remove outer thrust plate. I added this photo to clarify orientation
Automotive tire Gear Rim Gas Auto part
13. Remove pump ring
Motor vehicle Automotive tire Watch Automotive design Rim
14. Remove rotor and pressure plate - be careful to keep vanes from falling out of rotor
Gear Automotive tire Crankset Rim Bicycle part
15. Remove and replace pressure plate outer seal. Use a knife to carefully cut the seal
Wheel Automotive tire Crankset Bicycle part Camera accessory
16. Remove inner pressure plate seal (put it on the pressure plate when you replace)
Automotive tire Motor vehicle Automotive lighting Bicycle part Rim
That is it for the pump itself. Carefully re-assemble. If you have cleaned parts, apply a thin coating of ATF when re-assembling.
Note the proper orientation for the rear cover plate when attaching.
Banned
Discussion Starter · #2 ·
17. Remove the flow control valve/union fitting (pressure hose connection).
Bicycle part Gas Camera lens Automotive tire Auto part
18. Replace outer o-ring on the fitting
Household hardware Wood Gas Screw Metal
19. Replace inner o-ring
Household hardware Wood Gas Audio equipment Machine
20. Re-install fitting
21. Re-attach pump to oil filter housing - torque 22Nm (16 ft-lb).
22. Attach supply line and clamp securely
23. Re-attach pressure line with new crush washers - torque using crow's foot (90 degrees to shaft) 40Nm (30 ft-lb)
24. Re-attach pulley to pump and finger-tighten screws
25. Re-install serpentine belt
26. Torque pulley bolts - torque 22Nm (16 ft-lb).
Refill and bleed
Refill and bleed
Matt,
Did a terrific job in compiling this DIY, Photo Tutorial, for the kit, he purchased from me.
I never quite had the time to write up my own Tutorial, as I focus now, on only doing Rebuilds.
And Matt also included a link to my website, (see above) or Google (jay bigcoupe) to purchase a DIY KIT.
PLEASE READ, the top of the first page, to learn the trick to be able to turn on the photo caption feature.
Then go to my Link # 9.
I found I could not make a living just selling kits, as there is very little volume sales.
Best, Jay
Thanks again Matt!
1 - 4 of 4 Posts
