1 - 10 of 10 Posts
Hi-
I did my lower control arms, bushings and bushing carriers. I shot some video and slapped it all together. Parts: Hamman lower control arms and bushings pre-installed into new carriers. All off of Amazon, ran me about $270 in parts, $10 for the pickle fork I didn't have.
https://vimeo.com/83072647
What I left out was installing the bushings onto the control arms. Basically, I just used some soapy water so slide them on (beat it a bit with a dead blow) and then let it dry.
I took about 3 hours total of really taking my time. Driver's side is MUCH harder than passenger side. (Passenger side I did second and it only took me about 45 minutes.)
Enjoy!
Wait, so you did not need a press tool for the bushings? I'm considering buying used control arms from Bav auto recycling because they offer to pre press the bushings in..
You can purchase the bushing housing with a new bushing installed.
I purchased new control arms with attached bushings, if you wanted a complete and easy swap.
no way to get socket and tq wrench on either inner or outer bj nut, how did you q to spec?
Yeah do tell. I have a set of arms at the house and I looked into doing this but see no way to torque them. I also have not come across any other DIY talking about this either.
i just wrench tightened the sheet out of em
you need 4 box wrenches
18mm,19mm,21mm,22mm
19 can be rachet but don't bother with others, can't get box end on inner bj nut , need to use open and flip
Not to rain on your parade......but the brand of parts used, are not the best quality.
People been using meyle hd ca for years
Enlighten us
Edit:
Had this confused with another thread
Yes op
Amazon no buenos
I got meyle hd from bma parts for $320 shipped
Full kit
Buenos
1 - 10 of 10 Posts
