1 - 3 of 3 Posts
Please help or direct me somewhere where I can find M56 specific for this job.
I have search YouTube and nothing but non m56 DiYs.
Even on Pelican Parts and even searches in this community and just a lot of M56 swap pops up in the search.
I doing this removal and I'm stuck, on removing the harness that goes into the injectors. There are two wires looms on the rear of this harness.
One is on one side of the intake runner and the other is on the other side of the runner. Both runs through the holes and down to the distribution box with no electrical connectors to disconnect these things. How do I disconnect these so I can remove the intake?
Do I open that plastic electrical harness rail and....?
I will attach images
Thanks in Advance
And hope I posted this in the correct spot
Discussion Starter #3
I want to update this. I finished this last Sunday morning.
I did figure out how to remove that harness. The inside wire does not run back to the distribution box like I thought, but the outside thicker wire does go to the box. Instead, the inside wire is a short wire that connects to a plug that's right below the 6th intake port.
And now that I think about it, I believe in 50skid DiY video he briefly shows that plug after he lifts the intake a little bit.
I'll attach images, hope this helps anybody else.
1 - 3 of 3 Posts
