No guys, this don't work.
Sedan LCM works only for sedan
I have done this, but ok.No guys, this don't work.
You have done:I have done this, but ok.
I sold my touring LCM to another user who has it functioning in his sedan.You have done:
facelift sedan LCM on a touring. ✅ will work.
touring LCM on a facelift sedan. ❌ will not work
If you done a touring LCM (LL) on a facelift LCM (LH), then please share witch us. I did everything you said, I did everything in NCS...it not works.
No I tried it and it don't work for me.I thought it's because of the different (?) pinout because of the inner tailights and then the outer right tailight not working? Or is it solved just by defaulting the configuration of the new LCM to your car by writing the blank .man file?
Was it a pre facelift sedan?I sold my touring LCM to another user who has it functioning in his sedan.
Why would there be a touring-specific LCM when for all intents and purposes they're identical cars?
It is not fully correct. It worked like this with pre facelift LSZ (CI:26-CI:29) that all versions of one coding index had all same hardware and to change from halogen to xenon and vice versa it was OK just to change the front panel and recode the LSZ.I don't understand any of what you're saying.
LCMs can be used in any coupe/vert/sedan/touring/compact, it's in how they're coded that determines what pins are lit under what circumstances. IIRC the one that I currently have in my touring had originally been in facelift sedan, but I've had ones out of coupes in it in the past. I've been through a few before finding one with sw version 4.0 and the circuitry to drive the xenon leveling motors.
Just curious how do I read cpu, you mean at " interface menu" and choose detect usbdm interface?LSZ2 CI:35 for Xenon and Sedan with RLS - this is the very right LSZ2 to use.
I guess You did it, but if not, please check all those hints.
- Check and double check all the software and drivers version You installed. There should be the proper match between the system and the version of the SW (e.g. XP 32 bit version on WinXP 32bit computer).
- Check and double check the location and proper soldering of the pins on LSZ2 PCB You soldered the wires to, proper wires assignement for flash tool connector, propper connection of the connector to flash tool (not reversed if the connector is DIL flat ribbon and not individual wires)
- Check and double check jumper settings on the flash tools
- If it still does not work, try to get/borrow another computer, e.g. with Windows XP and try to install all SW there, when installed, test it again
- I always read the CPU first to test connection, if read successfuly, I save the result as well
If none of this helps, I do not know what to do next...
