21 - 40 of 51 Posts
Hi GTRaptor and rorschach
Great DIY!
A couple of quick questions if you don't mind...
- I have a Business Cassette HU with CD changer and 'Mode' button. Is this Aux capable, i.e. can I plug in an Aux cable?
- You mentioned in the DIY PDf exactly what I was thinking! Where would I splice in a switch to change between Aux input and CD Changer?
- Are the capacitors and resistors necessary? What do they do?
Forgive my ignorance... help much appreciated!
Cheers
Can you tell me what the resistors do? I found the capacitors but i'm having a little difficult time with the resistors of that value. are they necessary?
I believe they are there to generate a load so the HU will display AUX when switching between modes. If you don't have them then AUX will only display when you have your MP3 player hooked up.
Nice DIY OP :thumbsup:
Guys
I made the cable and connected to my Business Cassette HU - awesome DIY and hella fun doing it!
I can connect the the cable without connecting up the CD changer to the other end and I get full, proper sound from my MP3 players. Weird huh?
FYI, the HU is a Philips unit, and appears to have a separate Aux connector. Will make up the Aux connector cable sometime soon and try it out.
Cheers...
That's perfectly normal. The small 10-pin connector is *just* for sound from the changer, the control signals that are needed to fool the HU come through the larger harness at the back of the HU.
Thanks for this DIY.
I did this in a couple of hours last night.
Some notes which may help others.
I didnt use the capacitors and resistor on the AUX cable.
The only impact I see is that "AUX" doesnt show until you power on your Ipod.
Edit : impact is also that you can't charge and play IPhone at the same time when using cigarette lighter and AUX cable
After installing the Capacitors and resistors charge and play at the same time works.
I used computer connectors from old computer case, these were for LEDs and Hard drive.
I used two, 2-pin connectors for the 3 connections needed for AUX cable.
To take out the Radio Head Unit, first remove right side dashboard panel, then center panel above the radio.
You cant take off the center dash panel without first taking off the right side dash panel.
For the 3.5" mini stereo plug, tip is Left channel, middle ring is right channel, and base is ground.
I had to look this up.
http://en.wikipedia.org/wiki/Stereo_plug
Look near the secton called Tip/ring/sleeve terminology
There is a table and a photo.
I took off the Manual transmission boot, undid some screws,
then removed lower storage bins.
See Going Nuts dash tear apart for pictures.
http://forum.e46fanatics.com/showthread.php?t=644722
Post #12 and #14 were helpful in getting the Manual transmission leather boot off,
and the lower storage bin off.
For getting the dash panel trim off look at the earlier pics. Post #5.
But my car is a Left hand drive North American, so the trim pieces are different.
I removed the passenger side/Right dashboard trim piece first, and then the center dashboard trim piece.
I threaded the 3.5" stereo cable down to the bottom storage bin,
and then just friction fit the cable with the bin.
There's enough clearance to get the cable out, no need to drill any holes.
I will try and take some pics tonight.
Thanks again for this DIY.
I now have Ipod and Pandora from my Iphone in my car.
More pics
Pics of:
3.5" Mini Stereo cable coming out the bottom storage bin
Bottom storage bin ashtray insert removed, showing cable threaded thru hole
Bottom Storage bin cover closed, note it does not close exactly flush,
so if you want flush fitting you may need to drill a hole or find another place to route the cable.
Also, note that the cable will get somewhat compressed, depending on it's thickness, so there is the chance to break it if it is fragile.
My cable was fairly thick, and strong, and while the outside rubber is compressed I dont see any danger to breaking the cable.
A thinner cable might fit better, but not be as strong.
Below first pic, bottom bin door closed, not exactly flush
A little more explanation of the cable threading.
I had to remove the Manual transmission boot, the plastic cover surrounding the transmision (but I did not disconnect the window switch connectors) just enough to get to the screws for the lower bin housing.
I remove the lower bin housing enough so that I could thread the cable from the back of the stereo headunit, down to the lower bin.
I did not have to completely remove the lower bin side housing, just loosen it. I think 6 or so screws removed in total.
I did not remove the seat warmer switches or the Air con/Heat controls, those remained untouched.
I did remove the upper storage bin, which just pulls out no screws involved, this helps to see where the cable is and in threading it.
I was just able to fish the cable from the head unit back, all the way down to the bottom storage bin.
It's not hard, and should be easier for people now with the pics I took. I was a bit apprehensive at first about removing dash panel trims, but as long as you use a small screwdriver and maybe tape it to protect the dash, and carefully pry, it is not hard. Just work from the edge and use small force at first
Cable length was about 2 feet for the 3.5" mini,
the PC computer LED cables were another foot or so.
Total length of the cables was approx 3 feet, which is more than enough to reach the bottom ashtray bin.
I have at least a foot of cable coming out the bottom bin.
If you want less, you can just leave more of it behind the dash.
I just want the extra foot at the bottom to maybe extend further to cup holder if needed, but in fact I didnt need it, as I place the iphone in a dock which rests in the ashtray bin.
I probably could have done with 6inches or less of 3.5" plug at the bottom bin
Question for anyone who has done AUX cable DIY.
When I connect Iphone to cigarette lighter and iPhone charges, and use the AUX cable, this cuts out the AUX signal, and no music plays.
The iphone is fine with the AUX cable and bagttery power only.
This is both using an Iphone dock with line out , and the headphone out.
Is this an iphone thing ?
I can live with battery power alone I guess, as most of my trips are about 1 hour.
Found this on another 20 page thread, will try the caps and resistor and see if that solves the iphone charge and play at the same time issue.
Originally Posted by demens View Post
Quick question:
How to play music and charge at the same time (using the cigarette charger)?
Everyone mentioned ground loop isolators or noise filters. Another poster talked about the cap/resistor in the proper cable. So i'm confused. In order to charge and play do you need the caps and resistor PLUS a ground loop isolator or do people with the simpler cable need that?
I'd imagine either-or, as the caps & resistor circuit acts as a noise filter. I can verify that only using the caps & resistor allowed my iPod & iPhone to both play & charge.
21 - 40 of 51 Posts
