1 - 1 of 1 Posts
so my brake light went on a few days ago and i thought.. well time to get new pads/rotors.. but before i did that i took the car to my fathers garage and changed the oil, spark plugs, cabin and air filters and decided to take a closer look at the pads..
after checking the front ones i went towards the back and found that the sensor cable itself popped off the plastic hold and was pretty much torn... i didn't have the part on hand so i decided to fix it on the spot (i hate having lights on in the dash).
i couldn't solder it so i decided to go this route. you can see in the pics. my only suggestion was to have smaller tubes.. i didn't so i ended up filling the ends with silicone to keep moisture out to avoid corrosion of the wire.
saved me 20ish bucks.. i just like DIY's and home made fixes. light went off after driving the car and restarting it.
good luck.
bests,
john
1 - 1 of 1 Posts
