So, I did my searching with no luck at all on the topic but anyways, here it goes.
Yesterday my oil level light came on, I know that my oil level indicator tricks me quite often (I know how often these things go bad), however I went to check my oil to be safe and it read low... There was also cracks on several spots in the plastic of my dipstick which is new to my knowledge. But anyways, I added half a quart to be safe and checked again- still read below the bottom line. However, I see a small sliver of oil along one side going up to the top line. Could it possible that these cracks are causing my dipstick to not read correctly and that I have a faulty level sensor?
I checked everywhere for leaks- I looked around the drivers side if the block- no oil, none around the VCG or anywhere else on the passenger side, checked my coolant and there was absolutely no signs of oil in there. I also cannot see smoke or smell smoke or burning oil from the exhaust at all. And I also did my CCV only 2k ago so it's not that.
Any help? Could my dipstick tube also be clogged up? I'm planning on taking it out and seeing if there's anything restricting oil flow in it.
