1 - 12 of 12 Posts
ILCUTAWOOTIE
dinan quoted me throttle body for 500...i alreayd have an intake...
do i need the software from dinan too? I guess my main concern is, will there be a fault code on the bimmer if i just put in the dinan throttle body w/o software?thx much guys
-ALex
You will need the stage III software to take advantage of the High Flow Throttle Body. I don't think it will code on you without the update but if you buy the TB they should update your software at that time.
Do you have any Dinan software now?
You could always check out Technik too... They have a TB, but that also requires ECU reprogramming as well from what I know...
It might be cheaper though...
In Pursuit of My J.D.
What kind of performance gains are you expecting out of the throttle body?
Dear Lexie330ci,
I have the Dinan throttle body installed in my Super charged 330Ci. NO, there will be NO fault code on the bimmer if you just put in the dinan throttle body w/o the software. I had no fault at all in my car.
I suggest to get the latest software from dinan after you complete thier full kit ( just to avoid reprogramming your ECU every each and a while).
Take it bit by bit and you will enjoy modifying your bimmer.
Best Regards,
Rakony:thumbup:
I was told that that you just pay an extra $100 to upgrade the software from Stage II to III when adding the TB.
My Dinan rep told me the same thing. When you move to the next level of software, you just pay the difference. IE Stage 1 is 399 and Stage 2 is 499. Once you have Stage 1, it just costs $100 to move to Stage 2.
Resident CF Whore
Rakony said:
Dear Lexie330ci,
Best Regards,
Rakony:thumbup:
Supercharged? Then you had to change the airbox out, right?
I guess you can use the TB w/o the Dinan intake.
BMW Northwest was giving me sh!t about having a GruppeM and having compatibility issues with stage 3 and tb.
software upgrade is free if you've paid for the stage 1
you wont feel much difference at the low rpm after you get the TB, but if you plan to get s/c, it'll be another story...
They upgraded my ECU from Stage 1 to Stage 2 for free because I had already paid for Stage 1...
1 - 12 of 12 Posts
