1 - 3 of 3 Posts
Got a question for anyone that knows about the Dinan software. I am probably going to purchase at the least the Dinan CAI and stg 2 software. I' m also seriously considering adding a Nitrous setup just for a few extra horses every and now then, and for looks at shows. My question is what exactly does the Dinan software do as far as programming. I read it adds fuel for the added incoming air. Which would not be a problem, when using nitrous also. My concern is that if it adds timing to the engine then I could run into some detonation problems which I don't want. Any help would be greatly appreciated
Steve Ricketts
you cannot use the dinan software and nitrous. The dinan software advances ignition timing and this could cause detonation. The only way to get a software upgrade is to get a custom software upgrade that doesnt advance ignition timing. Hope this helps
I had the same question a while back because I am going to do an NX 75 shot sometime next year. The replys I got back pretty much indicated that an upgraded ECU with advanced timing would not be good. Only some expensive custom programing, engine management system or dual maped chip would work. I decided to save the money on a software upgrade and just put that money into some good safety devices for the nitrous upgrade (like fuel presssure cutoff switch, A/F meter, colder plugs, and rpm limitter).
1 - 3 of 3 Posts
