1 - 3 of 3 Posts
ok, so for sure i need to by extra wire to connect my DAE and "tap" them into my fogs, my fogs are the 2002 sportspackage bumper fogs.
FYI: i got my DAE from fiberdesign so maybe that will make a diff in length of wire
and if i do need to buy a wire what kind or whatever "the gauge number"
Banned
Not sure on the fiberdesign kit but there should be a blue wire coming from a relay. That wire needs to "see" 12 volts thus you can either wire to the fog light 12 volt wire or you can run it towards a switch.
AIM me: s4playko if you need help.
rk
Site Sponsor
DAE are probably wired up the same way as Gen IV.
That is the bulb probably receives a positive and negative wire.
However, unlike Gen V, there is no trigger, each light box probably requires that it be connected to a trigger point - in this case the fogs.
Don't worry, the bulbs have no polarity, so you can't mess it up:D
1 - 3 of 3 Posts
