Okay-
So I know everyone has been trying to get some hard data on the stock HK speaker sizes... so here is my contribution... I pulled the door panels off my 2002 E46 M3 coupe and measure them myself.
Hopefully this will take the guess work out of swapping out speakers and upgrading...
In my 2002 E46 M3 with HK sound I have the following speakers...
In the front doors, three speakers each door, 6 total for the front stage as follows:
2x Tweeters 37mm 1.5inches overall diameter. The dome is about .5-.75 inches.
2x Midranges (Top of door next to tweeter) 60mm/2.3inches overall diameter. 37mm/1.5inches deep.
2x Midbass(Bottom of door) 160mm/6.29inches diameter metal speaker basket overall. Cone is 120mm/4.75inches. The overall diameter from bolt hole to bolt hole on center is 190mm/7.4inches on the PLASTIC mounting flanges, of the adaptor the speaker is mounted in. Speaker is marked 21watt, 3ohm btw. Also there is space ring between the speaker nad the door that offsetst this driver from the door by 10mm and has roughly the same overal diameter as the driver. There is some additional space better this ring and the grill, about 20mm to be had with some careful triming.
In the rear:
2x tweeter (I didn't pull the panel and measure)
2x Midbass same exact demensions as above Midbass. Identical speaker. Reardeck
2x 6x9 woofers Center of rear deck.'
This makes for a total of 12 speakers. However the Tweeter and the mid in the upperfront are both power by one pair(positive and negative) wires. There is small resistor on the tweeter which I assume is the crossover. Even thought the front looks like a 3way system, and technically is, it is not tri-wired, it is wired like a two-way from the amp.
Note: These are the stock demension...this does not mean that this is the max speaker size you can fit. There is clearly some room for a deeper and larger 6.5midbass in the front lower doors with some trimming of the plastic. These specs are for a E46 Coupe with HK, 4 door sedans are different because the front doors are shorter.
Pictures to follow.
For now go here for pictures if you registered on this forum...
http://www.m3forum.net/m3forum/showthread.php?p=679285#post679285
In the rear:
Pictures to follow.
