DDE Gen V Install (kinda long w/big picts- sorry)
2507 Views 31 Replies 19 Participants Last post by  jsp98m3
First let me say if you don’t want to read another DDE install thread, STOP! LOOK AWAY! LOOK AWAY!
I received a very well packaged kit from Umnitza last week and installed it this weekend. I can’t comment on anyone else’s products or compare brightness, fit, etc since I’ve never seen or experienced any kit of this type first hand. (Other than the picts posted here)
First, I have to say that Matt is very accessible, and very willing to help. I have emailed and IM’d him several times and he has always been back to me quickly, even on Saturday. The installation is not technically very difficult, but it is time consuming if you’ve never taken your headlight assembly apart before and have a good healthy fear of screwing something up. Almost like taking apart your gauge cluster to install overlays only on a much bigger scale. Since you’re dealing with expensive parts, I was a little afraid of damaging the xenon assembly but everything went well. It took me most of the day working on and off. If I were to do it again, I think I could get it done in about 2 hours.
The rings, clips and light boxes are all nicely made, and there is an abundance of heat-shrink tubing, and wire ties, mounting screws, etc. included. The light boxes are a little bigger than I thought, a function of the bulbs and spacing I suppose. The trim around the headlights wasn’t too difficult to remove. You have to fight with it a bit, push here, pull there, but it came apart without anything breaking or scratching. I installed the fibers in the kit by drilling 1 hole for all 4 fibers roughly in the middle of each headlight assembly. I think that’s the cleaner looking way to install it, but drilling an individual hole in the right location for each fiber would help ease the bends necessary to route the fibers the right way and connect to the ring. The point at which they connect to the ring is a tight area so having them find their way through the assembly at the proper angle without too much bending is important. Reassembling everything went remarkably well, usually it’s much easier to take things apart than put them back together! They are definitely bright, noticeable and interesting to look at. I really don’t know enough about what’s changed in the different generations but I think what might be one of the best aspects of the Gen V kit aside from their visibility during the day is the fact that everything that can possibly be done for you ahead of time, is. It was VERY helpful to have the clips, wiring, end connectors, the relay, wire loom, light boxes etc. all pre-assembled and ready to go right out of the box. Visually, other than the light boxes themselves, there is almost no obvious wiring or parts under the hood that isn’t nicely wrapped or covered. I wired them to the fogs for now; I may go with an interior switch at some point for more control. I drove around town for about an hour with them on and the rings stayed in place perfectly, and look very evenly illuminated. The boxes get fairly hot, but I think most of that is because of under hood temps. They cooled off completely in just a few minutes after I got home and popped the hood.
If I were to change anything, (I think maybe Matt already has or is going to soon) it would be to update and consolidate the install instructions. To me, there are too many install videos, promo videos, pdf’s, etc out there that apply to old versions or include steps that aren’t required (assembling of light boxes, wiring, more than 1 place to drill holes.) That VERY minor point aside, it’s a nicely packaged, well-supported, high-quality item. If you like the look (I do!), it’s definitely well worth it. Thanks again Matt!
Check out the picts and decide for yourself - they are taken about 30 minutes before sunset. It looks a bit darker than it was since I took them with no flash . Other than a bit of a "corona" effect around the light rings and fogs in the 1 picture, the picts are very representitive of how it looks in person.
See less See more
21 - 32 of 32 Posts
Those are bright :thumbup: but to many wires and loom all over the place. DDE and DAE need to make it more compact. Maybe finding a way like the LED no light box :dunno: Im not sure if anyone else would agree with me but I like clean installs.
Well u need 2 wires and 4 fibre optic cables minimum from each lightbox. Not much better u can do besides the LED route.... even the OEM setup uses fibre optic cables albeit they look a lot better in their black casing :)
Jano, did you use tape to mount your driver's side light box? It looks like you did not use the supplied bracket.
Awesome job, BTW!
No, actually the is a small indentation or gap between the fender. I slipped the end of the bracket in there, drilled a new hole in the bracket closer to the light box and mounted it. If you were looking at it from the other side, you would see about half the bracket. If you want a pict, PM me, I'll take one and send it to you.
Thanks for the comments!
As sick as I am of angel eyes, I tried to help a good friend install his demon eyes on his 740iL this weekend. They were purchased from Omnitech Motorsports.
I have the 3 generation DAE. I have to admit that the DDE's were a royal pain in the a.s.s. to install. We finished the installation and wired them up, one of the fiber optics started to burn. Also the light boxes have no glass, the fiber optic was bundled so tight in shipping that there were crimps, and the plug kept coming out of the back of the bulb. What I am going to do is talk to Herb to see if I can remedy some of these problems.. Granted I re-installed my angel eyes after the initial installation, I am not a fan of the design of the DDE's. Also, the ring on the DAE was 5 times brighter than the DDE (we broke one DDE and replaced with an extra DAE we had). Big mistake... :thumbdwn:
See less See more
Have your friend contact me, he most likely had a Gen II setup, I will guarantee that if he goes ahead and gets the Gen V upgrade, it will blow his mind away. No ifs, ands, or buts.
I'm very serious. I'll make him happy (seeing as how I have one -e38- I'll be able to help him with all of it).
BTW - here's agreat place for the bracket to attach to with NO drilling on the passenger side.
See less See more
what's the difference between DDE and DAE (devil vs angel) besides a naming convention??? :dunno:
please do an exhaustive search.
this topic is covered many times over.
also, if you need details, send me an email.
Does this set come with the different filters? I would love to see the blue-ish filter producing a light that bright
we will have blue light bulbs as replacements for the no longer offered blue filters.
The light bulbs are WAY easier to deal with than with filters.
What's more, there will be a small smattering of HID blue ring sets available for a limited time. If you look at the video no my site, you'll see how easy it is to swap it out.
For the person with the older unit purchased from Omnitec, I don't know when you got it but Omnitec appears to have some stock left over from a year or so ago, probably Gen II units. There is nothnig particularly wrong with the rings from those units in and of themselves but the mounting system is not current, state of the art. Particularly for E46s.
I would encourage anyone with an older kit to see Umitza or other board sponsors that carry DDEs to get an affordable upgrade. Trade-up policies are VERY liberal.
Gen II is NOTHING like Gen V.
21 - 32 of 32 Posts
