Data-filing difference from IKE to LCM
1 reading
50K views 32 replies 14 participants last post by  Bali
#1 ·
2004 E46 XI. I am the original owner. Almost 200K miles.
After experiencing what I can only describe as "strange electrical things" a year or so ago while running the car to bleed the coolant system (a bunch of codes I had never seen before, but all "not currently present", outdoor temperature was -128C, gas gauge movement on its own), it's consistent that I'm always getting a code that complains that the mileage is unable to be written to LCM. I use PASoft. When first starting PASoft, IKE indicates the correct mileage (currently, 319146km), but LCM never moves beyond what I write to it (last value I wrote was 318500km). PASoft shows this as a red discrepancy when it first starts up, and IKE throws a code when scanned for errors.
BE [190] Data-filing difference to central light module (LCM)
I've tried:
- recoding the LCM
- recoding the IKE and recalculating the checksum
- reprogram LCM using "Copy FA Coding", "IKE->LCM"
Done all of these multiple times. Still, after driving for a bit, the LCM mileage doesn't update.
IKE and LCM are original and have never been removed from the dashboard.
This in no way affects drivability of the car or anything else noticable except when scanning.
Any ideas?
#2 ·
Try to locate a wiring diagram and check the wiring that goes from the cluster to the lcm. It’s possible that there could be a short. When you find the wire or wires remove both and check the continuity to make sure that they is not a break in the wiring. I’m pretty sure that the cluster gets the info first and passes it to the lcm.
#5 · (Edited)
Try to locate a wiring diagram and check the wiring that goes from the cluster to the lcm. It***8217;s possible that there could be a short. When you find the wire or wires remove both and check the continuity to make sure that they is not a break in the wiring. I***8217;m pretty sure that the cluster gets the info first and passes it to the lcm.
No way. Not a wiring problem. Sounds like the non volatile storage chip in the LCM is bad. Not sure if it's internal to the microcontroller or a separate chip, but, it sounds like the LCM needs to be replaced, or just live with it. If you don't read the fault codes you wouldn't know the problem is there.
#11 ·
Replaced faulty EGS transmission module. Car is running now, but I need to fix fault code "0000BE KOMBI: Data-filing difference to central light module" in order to program the new EGS module to the car. Code Type= ABL "Read out LCM operating data" (ABL-DIT-S6300_00001 - Read out LCM operating data - V.5)
Anyone know how to correct issue to clear fault?
#17 ·
I never solved the issue that I noted in the original post.
Seeing some of the subsequent replies, I've since found a handful of posts (here and in other forums) that seem to indicate that IKE->LCM fails for any value greater than 300,000km.
It's notable that when I first discovered this issue, my car already had more than that.
#21 ·
I went through my notes and confirmed that this FIRST occurred on my vehicle when the LCM was stuck at 300,000km. This was back in December 2017. I even took a screenshot from PASoft (IKE was 301,447, and LCM was 300,000). Combine that evidence with multiple people saying that 300,000km is the limit for IKE->LCM transfers, and that's pretty conclusive that this is a known problem with no fix.
#30 ·
I've tried:
  • recoding the LCM
  • recoding the IKE and recalculating the checksum
  • reprogram LCM using "Copy FA Coding", "IKE->LCM"
Any ideas?
BE Data-filing difference to central light module
Could be simple - I replaced interior lights with LEDs in the front, but not in the back seat (didn’t have time at the moment), and this came up on the error list. Got the two in the back seat changed a couple weeks later, cleared the code, and it remains clear now.
Apparently the LCM expects all bulbs to send equal power usage (usage filing) within a group; however, the LEDs are sending a lower signal and triggering the message regarding inconsistency.
Could be something along these lines - LED replacements in some but not all lights in a group - running lights, interior, dash, trunk, license plate, etc. You may try switching back or replacing all in the group circuit with matching LED or non-LEDs.
#31 ·
did you read the thread through?
it’s because the LCM can’t accept more than 300,000km (186,411 miles).
