1 - 13 of 13 Posts
I am about to install my Herb's DAE..
I got everything working except now i am stuck with wiring problem. Is there any way i can wire them so that they turn on by itself without me touching anything??? I figured if i wire it to the foglights i would always have to hit the foglight switch to get them working. Is there anyway i can get them to work like Daytime Running Headlights????
Please help me...:thumbup:
SBBMotorwerks
IF you cant quite tell.....you see two thick red wired right toward the bottom of the ECU....just behind that you can see the end of an arrow pointing to a green wire...thats your wire
Great info! Do you have a bigger pic by any chance?
Discussion Starter #6
That looks very complicated to me.. That you what i have to go through to have it run like DRL??
SBBMotorwerks
Its, simple....just tap into the green wire....thats it
thais0n,
Are you using a relay or are you taking the DAE power straight from the DRLs? What's the current draw when the high beams are on?
Yeah, I would say... It couldnt be any easier this way....
just turn on the key and there on. Off and there off....
John V
SBBMotorwerks
I dunno, i just taped all the wires together...makes things alot cleaner.
I am not using a relay, just going straight to DRLs...not quite sure what the current draw is when the brights are on
An even easier method if you don't want to cut/strip that green wire is to just shove an 18gauge wire in there. Works fine as well.
1 - 13 of 13 Posts
