1 - 13 of 13 Posts
I am a little disappointed that the bulb has burnt out already (I did not touch it when I installed it) and need to change it after about 3 months of use. Do I just bend back the metal brackets that hold the bulb in?
Also, does anyone know when the next generation DAEs are coming out? I have been only mildly satisfied with the product for many reasons and wanted to get the next generation design in my car before I start trying to fix the problems myself.
Any help would be appreciated.
Gene
Just open up the metal box and replace the bulb. The bulb is a 35W MR-11 bulb. You can pick it up from a Home Depot or light store for around $12-$15.
Discussion Starter · #4 ·
There are metal brackets holding the bulb in - do I bend them back? Will they break off if I bend them?
more like $3 at www.allelectronics.com CAT#HLP-350. I've changed like 3-4 bulbs already cuz the tape couldn't hold the metal box tight to the wall of the ECIS intake. Finally drilled the heatshield wall and tied the box. No more problem! :D
http://forum.e46fanatics.com/showthread.php?s=&threadid=32540&highlight=dae+bulb
no, but be gentle :)
There should be only 1 bracket up top that holds the bulb in place. Just bend that piece back to remove the bulb and bend it back into place to hold the new bulb.
Discussion Starter · #9 ·
Thanks to everyone for answering! I appreciate it!
St. Louis BMW Fanatic
Discussion Starter · #11 ·
Vinny, could you address my other questions in my original post?
Discussion Starter · #12 ·
Vinny?
Discussion Starter · #13 ·
Does anyone know Vinny's email address?
1 - 13 of 13 Posts
