I just picked up a 2002 320 that won’t start. Starter is good, ignition switch is good, fuses are all good. I jumped the EWS module and I got it to crank. I’ve check all the wiring and all my powers and grounds are good. I’ve read that the EWS is also the starter relay? Is there any possible way to delete the EWS?? Or do I have to get a new one?
It only cranks when I jump the EWS connector, I thought that meant I had an EWS issue???
This guide is very good . But one possibility may be missing.
WHen you turn your ignition on, position 2, do the "normal: lights on the dash come on .. or just the odometer display?
If (and only if) you don't see the display. take the lower cowling off the steering wheel , find the big Black connector and probe green & purple wire. DO they each get 12V when you turn the ignition on (no cranking needed).
These do accessories. The green one has the pump circuit and the instrument cluster. If green has no 12V when your ignition switch is in Pos 2, Jump 12 V on that wire and see if you hear the fuel pump kick on. You probably will. If so try to start the car. If the car starts it will be your ignition switch or a loose wire in that wire pack connecting the ign switch to that black connector..
Please let us know what you discover ! -ourmandan-
