You should double check the part number on realoem.com to make sure it's the correct part number for your vehicle.Hey friends, thanks a bunch. I’m thinking this is the part right here:
BMW Windshield Cowl Cover - Genuine BMW 51718208483
BMW Windshield Cowl Cover - Genuine BMW 51718208483www.fcpeuro.com
I did replace mine with OEM but this is sooooooooooooo cool , nice one mate !!!!I cut the old seal about 1cm and slipped on a new weatherstrip from ebay for about £8 and £5 of new clips. Looks great and seals fine
used this: H-Type Rubber Seal Strip Trim Car Windscreen Door Panel Rear Edge Protector | eBay
Thanks mate, looked even better once the rubber had some time to relax and take its shape.I did replace mine with OEM but this is sooooooooooooo cool , nice one mate !!!!
Mart.
Agreed.It's a deflector, not a seal.
Look up the part number for your 2001 330ci vert on realoem.com, then price check on fcpeuro.com.I’m thinking this is the part right here:
just replaced mine. $99.99 from FCPeuro. first I ever returned (warranty replacement) $56.36 from 2014.You need to replace the Windshield Cowl. Not an expensive part - less than $100.
Note that not all E46's have the exact same windshield cowl, there are differences between E46 models.
puller no needTo help get the wiper arms off their mounts I picked up this little puller from Amazon - Battery & Wiper Arm Puller - so I didn't have to pry or yank on the arms and accidentally damage anything.
So the cowl under the wipers, while when it's in good nick deflects 95% of the water,
if it fails, you won't get a water leak. Unless you have a leak somewhere else, your heater plenum
tubes are plugged up, or some other failure's present, too.
Especially between coupes and sedans.You should double check the part number on realoem.com to make sure it's the correct part number for your vehicle.
I watched a video and they just used a screwdriver to tap the wedge up. No bleeding. No special tools.Couple other things to note: while I was in there, I noticed the cabin air filter was a disaster.....so I replaced that too. Also went ahead and replaced the air filter at the cold air intake box. Also replaced the little round plastic caps that go over the windshield wiper hex bolts.
In terms of pulling the wipers off.....well, I got one off with my hands. The center one wouldn't budge though. I pulled, and jiggled, and rocked, and wobbled...until my hands were bleeding. Then I gave up and ordered the tool for prying off windshield wipers and stuck battery terminals. That part sucked, but that tool was make it way easy.
Jonathan
