1 - 1 of 1 Posts
· Registered
Please forgive the ignorance, I've been trying to figure out how all of this works ...
1. In a setup using external amps... How does the fader (front/rear) still work???
2. Are the 4 channels of speaker output on head units bridgeable?
3. How does the typical 6 speaker setup in most cars run off the 4 outputs of the head unit? Are the front tweeters (on dash) and mids (in door panels) run in parallel, with crossovers or something?
Thanks. (p.s. The stock (non-HK system) system sounds sooo bad... ;0 )
1 - 1 of 1 Posts
