My e46 has a vacuum leak (I know that for sure) and I've checked and replaced every common vacuum leak source on the car over the past few months. I finally hit a wall and brought it to the mechanic so they could do a smoke test.
They found that the valve cover is cracked near the 6th cylinder (using the smoke test, they didn't find the actual crack visually). I looked around it and found nothing but then pulled the coils out and found that there is a chip out of the socket that the coil goes into on both the 1st and 6th cylinders.
So my question is, do the sockets/holes where the spark plugs and coils go in pull vacuum? It looks like they're separate compartments from the rest of the valve cover so I didn't think so, but it would be too much of a coincidence if not. If it does pull vacuum then I found the source of my vacuum leak and likely need to replace the whole valve cover.
Thanks in advance!
Pictures:
Thanks in advance!
Pictures:
