1 - 4 of 4 Posts
Banned
i got 00 328ci, bout to get my front clear corners tom., do the old ones just snap off, cause i looked under the hood and i dont see a screw, thanks
there's a hole in the fender right above the corner light. stick a long flathead screwdriver into the hole and feel around for a flexible plastic tab, push down and towards the front of the car, the corner will pop out.
its not as easy as he says, it may take a while to get the head of the screw driver onto the right tab and once you do make sure it doesnt slip, a flashlight will help you locate the tab.
1 - 4 of 4 Posts
