So my car all of a sudden stopped cranking, so I changed the starter and it worked! BUT during the job I removed the intake manifold and coolant hoses to reach the starter. Everything was fine until I noticed the coolant light came on, I checked under the hood and one of the hoses came off so I fixed it. Poured more coolant to max level. Now after taking it out for a spin the temp went red and the the coolant light turned on then off and right after that the oil light came on. What do you guys think it could be. This car was perfectly fine until the f** starter went out. I also did not put a new gasket on the intake manifold
UPDATE**
so my dumbass didn’t bleed the coolant system (had to remove upper hose driver side, there’s two of them did that to reach bottom starter bolt.) so after putting everything back together I bleed it and she was thirsty took another gallon of coolant. After bleeding she ran like a charm!! Digital temp (test 7 on dash) read at about 80-97 it would cool down when I would accelerate. Overall seems like she’s up and running mates thank you so much. God bless everyone and their e46.
UPDATE**
