1 - 8 of 8 Posts
Today plastic fitting of the upper radiator hose on my 2009 535xi (N54) disintegrated so I had to replace that. Last year I removed a hose from the cylinder head on that car and the mickey mouse style fitting disintegrated and left pieces in the head. When I replaced the hard coolant pipes on my 325i E46 last year they also broke off in the head. I wish they could have found a plastic that could stand up to time better. Still using the original rad hoses on my E46 and they look/feel fantastic still.
What disintegrated? The O-ring keeper plastic ring fell off the hose connector? The is a typical result when people didn't use brake grease lube on the O-ring and the male connector when put them together, and the rubber O-ring was bonded to the male part, then the owner try to force them out during removal and crack/separate the plastic keeper ring from the connector body.
2001 325i Sedan
I have a 2007 N54, and I agree 100%. The plastics, ALL of them, on the E90 are vastly inferior to those on the E46. Every bloody time I work on the engine, at least one plastic part breaks, no matter how careful I am. A lot of them have been replaced already. Except for hoses, all the plastics on my E46 are original, intact, and still almost like new.
The inner part of the hose connector, just behind the O Ring usually stays stuck onto either the radiator or the OFH outlet. See it all the time. Factory hose never touched (N54/55) from the factory.
It's part of our quote for the OFHG (2 of them) job.
Discussion Starter · #5 ·
The flange that the hose slips over broke in half. There was only about 1/4" of flange left to slide the hose back on to but not enough for a hose clamp to grab it on to. The o-ring and part that fits into the oil cooler was fine. When the hose came off the crimped ring on the hose was fine and inside the hose was a round plastic piece from the flange that stayed in the hose, under that crimp.
I have never seen the hose broke off from the connector as you described. The said hose connected to the oil cooler? Never heard of this.
OFH outlet? Am I missing something here, that the OFH connected to the coolant hose?
The conversation strayed, that was a N55 answer to a N55 situation.
1 - 8 of 8 Posts
