So I fixed the obvious broken wires in the top and the trunk. The top still will not actuate either direction. I struggled to get it fully down manually and latch the cover. It seemed like the valves were not relieving pressure. No fluid leakage and the reservoir is full.
In any case, I get a flashing red LED when the CVM is plugged back in after being disconnected. After 30 seconds or so, it goes out. I gave up and took it to the local dealer to have them read the codes. They are attached. The mechanic said that they all hate convertible top issues, because you can take from 3 to 10 hours to diagnose and fix.
If anyone has experience with this, I am dying to fix it myself. I think it might be the valve body, but I have no pin-out for that side of the CVM. The pin-out of the top switches and sensors is on these forums, but the other is not.
Does anyone near Allentown PA have the DIS reader, so I can recheck these codes after I reset them?
Thanks for any help you can provide.
