Hello everyone,
For the past few months, I've been experiencing a bizarre problem with the keyfob (diamond) of my car. I do have only one unfortunately, the rest are MIA.
The car is a pre facelift '02 Right Hand E46 318Ci Convertible, with hardtop attached (im mentioning this in case it's affecting the following description).
I bought the car April of 2019, i had no issues with the fob ever since. Until a few months ago, i started having issues with it.
The issues are:
1. The range of which i can press the buttons, has significantly decreased (almost about from touching the car with the blade, up to 2 meters away). I did try the good ol' chin trick, does nothing to fix the issue.
2. Pressing the buttons, rarely work in addition to the above and that leads to unlocking it manually, which we all know puts stress on the lock.
3. If i press the unlock button for it to roll down the windows (when it works) it cuts off midway, from top to bottom and vice-versa.
4. Sometimes when i unlock the car (when it works again, single press) and open the driver's door, the window rolls down by it's self (just the driver's side)
I did try re-initializing the key (turn 3 times then rapidly lock while holding unlock etc. etc.) Sometimes that does help but briefly, nothing significant.
I coded the comfort access options, a few months after the purchase, in PAsoft (roll up/down the windows/top) which for a weird reason my car didn't have them beforehand, just the normal lock/unlock. This was maybe shy of 2019 Christmas.
Everything was working flawlessly, but now it just doesn't work as before.
To be honest, I'm not sure if the problem started after the hardtop installation, which was a year ago, or the problem existed but i just didn't noticed it that much (because maybe it didn't happen very often to notice)
Maybe it's the fob's battery, or a faulty GM5 or even the rear view mirror.
All i know, is that it drives me crazy. Especially the range part, which is ridiculous holding the key next to the door lock for it to decide to unlock.
Thank you for your time.
The issues are:
