I'm diagnosing an issue with my stock 325i. It'd started to idle rough then over a couple weeks went down on power. Felt like it was a cylinder down. I assumed I had a bad coil. I went to troubleshoot the coils and then it wouldn't start at all. I had the coils out so figured why not compression test? Well the results were confusing not only because they were low but because they were inconsistent. I tested three times and got wildly different results each time. I pulled the fuel pump fuse, removed all spark plugs, screwed a brand new compression tester into a hole and cranked 5-6 times (when the needle stopped going up) with the throttle wide open. Pressure held until I released it so I don't believe the tester is failing to make a good seal. I know its ideal to do it cold but since it won't start it was my only option. I figured if all the results were within a tolerable amount of each other it'd tell me what I need to know. Here are the results for each cylinder. Commas separate test 1, 2, and 3.
1 - 42, 60, 61
2 - 149, 111, 121
3 - 59, 70, 59
4 - 83, 105, 72
5 - 50, 151, 116
6 - 31, 100, 30
How is this possible? I assume I did something wrong. I did put a scope down to look at the combustion chambers. Couldn't see much. Some carbon buildup but no pieces of ring land bouncing around or anything.
Extra context: About 6 months ago I had the intake manifold off to do CCV, coolant hardlines, gaskets, etc. Been running great since until the DISA started rattling. Rebuilt the DISA with the German Auto Solutions kit. All was well for a few weeks until this started.
1 - 42, 60, 61
2 - 149, 111, 121
3 - 59, 70, 59
4 - 83, 105, 72
5 - 50, 151, 116
6 - 31, 100, 30
