Confused about what INPA/D-CAN/ BMW Scanner etc can do
1 reading
15K views 19 replies 9 participants last post by  fanatichuman
#1 ·
On my 2001 330xi, which approach should I use, apart from my ELM327 w OBDFusion, to look out for my car?
I want to be able to diagnose/look for proper functioning of all main modules, like the transmission one etc.
Is there an overview somewhere on what I can do with which of the above cables/tools?
Cheers
#2 ·
There's no actual overview but I can try to summarize.
OBDFusion: Reads fault codes in a PXXXX format. Good for engine faults but not much else.
INPA/ISTA: BMWs own tools for diagnosis and scanning of modules. Extremely powerful and can read any module in the car.
NCSExpert/Dummy: Rides along with INPA for coding purposes. You can code things like used modules with this, check the link in my sig for an example. You can also modify some settings. Tricky to learn but extremely powerful.
BMWScanner/PASoft 1.4: Scanning and coding with little learning curve. Probably the place to start since it's its own cable and software, can read any module and has a GUI for coding thibgs like DRLs and auto locks. Can't code new modules to the car however.
I'd get PASoft and INPA/ISTA. The link in my sig has the info ablut what kind of cable you need for INPA/ISTA.
