1 - 8 of 8 Posts
Ok I've been trying to find out why. I noticed some E46 is fitted aircond condenser fan with and some without the fan.
I can't seem to find the answer why. Can anyone tell me?
926846
Auto trans has mechanical fan and electric auxiliary fan.
Manual trans has a single electric (puller) fan in place of auto trans mechanical fan.
Repeated info
(Bali posted faster)
Sent from my iPad using E46Fanatics
Discussion Starter · #4 ·
That's weird. So here's the thing.... I've noticed my buddy's car which is an automatic. It does not have the pusher fan in front. Same goes to some with an auto. Again some have it and some don't. So confusing.
Administrator
Many who have AT cars have removed the mechanical fan/clutch and pusher electric fan, and then installed just the puller electric fan for MT cars.
Premium Member
Here's the whole story:
Both the manual and automatic have electric fans. The manual has a puller fan behind the radiator. The automatic an "auxillary fan" ( important distinction BTW) with a mechanical fan and a fan clutch attached to the water pump.
The reason the automatic cars have two is because of the extra thermal loading. The transmission oil is sent to the intercooler at the bottom of the radiator and BMW wanted the extra margin because of the increased work placed upon the cooling system.
The electric fans, be it Aux or puller are the same motor (I'm told) however the puller design is in a different housing. Pulling air has a better cooling capability than pushing when it comes to radiators.
Many remove the fan clutch and go with the electric one and/or swap to the puller design.
Some notice no difference. Albeit I wonder if they're monitoring Atf temperatures and not just coolant?
Me...... I like the fan and fan clutch if the car came that way. I'm a huge fan of redundancy when it comes to cooling systems.
Like insurance, you never know how good it is until you need it.
Discussion Starter · #7 ·
I agree with the ATF temps. I rather have it lower even at stock. But why would ppl do that by removing the fan?
Premium Member
If you're referring to the engine driven fan, it's because it pulls more CFM than the electric.
Some doubt such. I point out how the E46 M3 is laid out. One of the biggest and most aggressively pitched mechanical fans BMW ever made.
So with the extra heat of the ATF, a mechanical fan was added. Removing removes that layer.
1 - 8 of 8 Posts
