Hi everyone, I'v been using these forums for ages and they're great but this is the first time i'v actually posted so hello all!
Basically, i'm very comfortable working on cars and I'v worked on several BMW's before, but when working on my own one I'v hit a brick wall with what could be wrong! I drive a 2000 328ci.
I basically removed the rear left trailing arm and replaced the RTAB and wheel bearing. A few days after putting it all together I noticed a clunking noise which arises when the suspension drops over a small pothole or something. Going over a ramp even at speed doesn't make the noise.
Since then I'v replaced the strut top mount and I also realised the coil top mount was completely gone so I changed that too.
The RTAB's were Lemforder, Bearing was FEBI (Best I could afford at the time), Top mounts are Meyle HD and the coil top mount is BMW OEM. The noise is STILL there and it is really loud now though.
Does anyone have any similar experience? I don't know if changing the anti-roll drop links will change anything. Its not a tinny noise so I highly doubt its the disc guard. I'v checked the driveshafts and everything seems rock solid. I feel its also very unlikely that the noise could be coming from the bushings/ball joints on the trailing arm as its such a prominent noise.
I suspect that I may have accidentally overtightened the bolt that goes through the RTAB and holds the carrier in place. This thought sounds stupid but I'm completely stumped and its making me so very miserable!
Any help would be highly appreciated!
Thanks in advance fellow Beamer heads!
