1 - 12 of 12 Posts
hey,
I have the UUC clutch stop and have a really hard time getting it into gear sometimes. It also sounds like it grind a little bit once in a while. I cant get the clutch stop screwed in any more but it looks in there pretty far. Any ideas? Should I just take this mod out? Thanks in advance,
i followed the DIY on that 330ci site, and it said get 50mm bolt. For me it was too long even screwed all the way in, so i switched it with a 40mm. Now, its good.
E46Fanatic
i cut off about 4 threads and it still felt alittle too high. cut off another 3 and that was perfect.
'a certain moderator'
hmm, i made my own, and had no issues. dont you have to adjust the engine start mechanism if u have it out very far? i made mine so i could just start the car barely, and its perfect.
cost me $0.29 too !!
-brendan
E46Fanatic
-brendan
UUC's clutch stop is at the borderline of the car starting or not. at first i couldn't start it, had to really screw in the clutch stop and apply some pressure on the clutch. the main reason i cut the threads was this and also it didn't match up right w/ the stock shifter. the throws are too long compared to the clutch w/ the stop. it would probably have a better feel w/ a SSK. but w/ a few threads cut off, it has a much better feel to it.
Well,
It's my belief that a lot of people have the clutch stops adjusted too high - that they are actually causing extra wear just because they feel the need to have shorter clutch travel.
If you are at the point where it may/may not start, that should tell you something.
Besides, if you really wanted one, just DIY....the UUC one is made of better material, but considering you can make one for change, you can put a new one in every month if you so desire.
I think a clutch stop is like leaving your foot resting on the clutch pedal as you drive...causing unnecessary wear over the long term.
If you want to do a clutch upgrade, do a real upgrade: TurnerMotorSports Flywheel and an upgraded clutch.
I disagree with Optimo.It has no effect on clutch wear. Is there any way to bypass magnetic switch,so i can bring my stop to point of clutch engagment????
E46Fanatic
OPTIMO said:
Well,
i'm thinking that this is why my clutch is completely shot. my car has 7,200 miles on but i sit in alot of traffic every morning, and i thought this myself. i think that w/ the stop cut down, it'll be ok, but at the height it comes, i think is no good. i bought my maxima brand new in 97' when i was 18 and couldn't drive stick. i learned on that car and sold it w/ 120K never replacing the clutch. either it's the clutch stop or a defective clutch. :confused:
will installing a stop effect my warranty? why would where the clutch engages have anything to do with the throw of ssk?
:dunno:
1 - 12 of 12 Posts
