Hey guys,
I’m having some strange troubles with my E46 and I can’t seem to backtrack the problem. Basically the car doesn’t want to go into gear or come out of gear when the clutch is fully pressed in. However, it can forcefully slip into first gear after already rolling by being pushed. Once moving the car has no problems shifting through gears. I had a shop install a Clutch Master Fx250 kit on the car, including clutch disk, pressure plate, HD throw out bearing, lightweight fly wheel. My mechanic thinks it could be my TO bearing, shift fork or pressure plate. I thought it was my slave cylinder because I lost some pressure. My mechanic also removed the slave and said it’s not cracked or leaking so it’s not that. The kit is brand new and just broken in ~1000 miles. If anything it could be the shift fork because that hasn’t been replaced. I’m also thinking it could be something related to shifter bushing? What do you guys think it’ll be? PFA
