Hello convertible owners (and anyone else that might be able to help).
About two months ago I swapped my red third brake light (the OEM neon piece) out for a clear one that I purchased from a member of this forum. Everything was fine until two weeks ago, when the brake light indicator lit on the dash. Low and behold, the "new" third brake light was no longer working.
I then ordered a new clear replacement from Circle BMW, and rather than drive a week with no third brake light, I decided to put my original light back in the car. Unfortunately, the original light didn't work when I put it back in the car. I then replaced the fuse, unhooked/waited 10 min/rehooked the battery to try to reset the error, and none of these actions fixed the problem. At this point I was convinced that I had two burned out lights (even though the original worked fine just before I removed it.)
Now the new light has arrived, and it won't work either. I'm baffled by this, and the last time I had an electrical problem, I left the stealer $600 lighter.
Any ideas?
Any ideas?
