1 - 17 of 17 Posts
Suck it easy.............
you don't need it...but it is recomended frankie......it shouldn't be that much anyways, so why not........
I'm finally gettin my alignment after almost 2 years being dropped, so thats proof that you will be ok without one.
"DPErt-ASchnizA-*****"
I never aligned my car after i got it lowered. She runs fine. no alignment problems. Tire wear are even on all 4 corners.
I holla
Re: Re: Changing Springs --- Wheel allignment necessary?
Choson1 said:
Just make sure you give yourself at least a week after installing the springs before you align your car.
i made this mistake with my previous car. you have to allow the springs to settle otherwise they'll wear out fast
I would do it
You don't *have* to do it, but why
be cheap? treat your bimmer nice and
it will treat you nicer.
unless the drop is 1/16 inch, first come
to mind is the
camber will be more negative.
When I installed my ACS
springs (1.25 front, 1 rear), I did it.
The print out from the alignment
machine showed more than just
camber differences.
Discussion Starter · #10 ·
hmm.. so its a bad idea to have it aligned right after i get the springs put in huh.... what exactly does this cause?
how about if you have coilover??? still need alignement?? guy who install my pss9 told me i don't need it.... if it was like lexus and other car, then i need to get a alignement.....what you guys think?:dunno: :dunno:
my tires all have even wear. and i never aligned my car after lowering.
i'm on OEM intake. lol, waiting for warranty to be over.
that sound a bit on the expensive side.
Over here, 100 for lower, DIY intake (30 at most), 70 for alignment.
1 - 17 of 17 Posts
