hi beams or low beams?
If it is just low beams, there is a plastic piece that has a twist off handle (like a wingnut) directly behind the bulbs. You turn these and they unlock, allowing you to pull them out with the bulbs. Then the bulbs just pull out. Getting them back in is kinda annoying, trying to line them back up and twist the knobs back on. If you're getting at both lo and hi beams, its easiest to just take out whole headlight unit
