I was on a 4 hour drive this morning and my CD player decided to quit working for me too. I turned it off for a second to listen for possible sirensbeanfree said:Went upto Maine for lunch. Had the CD player on for an hour and a half. Changed the CD and it refused to work. Put back the original CD (no luck either). Looked through the manual. No use. Radio works fine. Any ideas. Thanks.
did I read this right?Jimi158 said:I tried turning the car off while driving for about 30 seconds, but it still didn't work.
be carefull with that, when the engine is off your brakes stop working after pushing the pedal 3-4 times...DiscoStu said:did I read this right?
Thanks for the info. You were right. I disconnected it and reconnected it and it works fine. I was about to make an appointment to take it in. Saved me the hassle.evlthoma said:I had the same thing a couple of weeks ago: my CD-changer quit (but the radio still worked), at the about the same time I noticed that my turn indicators on the dash weren't working, the Auto setting on my climate control wouldn't work and the sunroof wouldn't open. I know none of these things are related, but I call the dealership anyway and the Tech tells me it's a software load error. He says to disconnect the battery for 5 seconds and all would be cured... he was right.
