CCV symptoms
1 reading
78K views 24 replies 11 participants last post by  Edvis1599
#1 ·
Hello e46 family!
I know the ccv is a wery well known topic but i couldnt just find detailed information about how to spot a failling CCV system. In my case a have a pretty bad oil consumption in my E46 320i, M54B22. I have it for only around a month and i made around 1.6k miles with it since i bought it and changed the oil and oil filter. Since then i noticed that the oil is getting low pretty fast, i topped it up several times, and during that 1.6k miles range i burned around 2 quarts of oil. Theres a bit of a leak through the valve cover gasket, but really its nothing major, no drips of oil, no smell in the cabin. You can barelly see oil on the exhaust manifolds. Theres no visible leaks from under the car also. Although when the car is running doesnt matter is car warmed up or still cold it gives a little bit of smoke from the pipes, it also smokes a bit (nothing major) when you accelarate from the stop light.
So im thinking maybe my ccv is faulty? And i cant find nowhere how to properly check if it is faulty. Found some videos on youtube saying that you need to take off oil filling cap and if theres a major vacuum your ccv is faulty, but mines has no vacuum when i leave the car idling and take the cap off. I need a bit of clearence how to check that CCV, couse i dont think that this kind of oil consumption is normal....
#2 ·
Remove all spark plugs lay them in same order and take and post pic. This will show how bad oil drinking.
#3 ·
Hello, i dint have the tools needed to do that atm, but since i changed my spark plugs around 2k miles ago when i bought the car i dont think they will be somekinda affected. I have my old ones though, i dont have any records on when it was changed last time, but when i remowed them, tips of the sparkpluga was covered with smth like a black tar. Not all sparkplugs, like 3 of them. So that means my postons rings are bad? As i mentioned, i burned around 2 quarts in around 1,6k miles.
#4 ·
Same engine and same symptoms as me. As the months get colder, I see a lot of white smoke from my tailpipes whilst at traffic lights. Sometimes embarrassingly so.
I used to see smoke in the warmer months too, but after fitting the 02 pilot vacuum tube mod (maybe read into this – but it isn’t an ultimate solution) it drastically improved.
#5 ·
Hey! Did i get that right? You did o2 pilot mod and the oil consumption increased? I called my local bmw mechanic and he told me that i need to replace my ccv, and clean or replace those plastic hoses.
I considered doing o2 pilot mod but i guess ill wait till i get that system cleaned or replaced. Update me on it goes with your case. Btw ehat is your oil consumption?
#7 ·
I would do this in a 2 step process. First replace your CCV valve and associated hoses and see how your oil consumption changes. Second if the improvement is not enough than perform the 02 Pilot vacuum line addition. Doing it this way you will have a better way to measure your results
It is like having your car not be running well and than changing all kind of parts all at once, your car will run much better of course but you will have no way of knowing how each part you changed affected the outcome
#11 ·
No post responders here on this have mentioned their odometer miles....Common, I have found for 'in-lines' at or around 100k is failure of the "Oil Filter Housing Gasket" A second concern at 100K is the CCV. A crank-case ventilation system...that by mechanical direction also gets burned out the tailpipe (via Catylitics). In America, cars imported, also including domestic, they too are required to meet USA standard emission requirement. Weather or not..and if you disagree...this is the law....
#13 · (Edited)
I don't think having major vacuum is a symptom of a bad CCV. I don't understand how the engine would automatically create more vacuum if the CCV was damaged when crankcase barely makes any vacuum to begin with.
If you had a broken CCV line anyway, you'd have a vacuum leak and less vacuum in the crankcase anyway.
Adding vacuum from the intake to the CCV is the only way to increase vacuum at the crankcase.
Replace your CCV, do the 02Pilot mod. Be sure to install a one way valve at the dipstick return.
#16 ·
Replace your CCV. I don't know what the pilot mod is, but I'd suggest you don't do it, since nearly every mod has some unknown, often unwanted consequence.
I'm at 335,000 miles and maybe burn 2-3 qts. in my 12-15,000 mile oil change interval. Also, OP, use an LL-O1 oil
#17 ·
Monitoring Fuel Trims is a good way to determine how well the crankcase is sealed.
With the engine warm and idling, assuming the STFT are below +5%, remove the oil fill cap and the STFT should immediately jump by 20-22%. If there is very little change in the STFT then chances are the crackcase has one or more air leaks.
Suggest you get the CCV replaced, make sure the engine operating temperature is correct, then monitor the oil consumption before you do anything else.
#19 ·
Hello!
So i changed my CCV a month ago and monitored my oil consumption almost every day. And i can say that changing CCV definetely helped. My E46 still burns a bit of oil, and as i heard from people its kinda normal. I guess i could do O2 mod, but i noticed that changing CCV increased vacuum in my valve cover, couse now when i try to remove my oil filling cap it is more difucult to do so, its being sucked a bit. Its nothing abnormal, i suppose couse it not really hard, it just barrely sucks the cap. SO i dont really know if increasing the vacuum even further doing that o2 mod would be really healthy to my engine. :)
It burns a lot less oil than it did before and i also found couple vacuum leaks while changing CCV. Im satisfied with my work results and ill keep checking the oil burning in my engine to overcome any other possible issues. :) I would say that changing CCV by yourself (especially if you havent done that before) is quite a job. It took me around 5 hours to do, and a lot of scratches on my hands. It looks like the M54 engine was made for people with tiny hands. :D
#20 ·
Confused
Hi Edvis, I just want to find out if the smoke stopped as well, also don't you find it weird that it increased the suction on the oil fillercap? People diagnosing a bad CVV all said this is the symptom of a failing CVV so im really confused lol, has there been a power increase feel?
