1 - 5 of 5 Posts
Need some help...
switched my water pump, thermostat and belts today - and I just finished, went to start the car and boom nothing...
When I turn the key, the xenons start flashing like mad as well as the cluster, and nothing else, and it makes a clicking noise....
Anyone else have this happen? Right now I am SOL.... :dunno:
I think there could be a short somewhere from draining my coolant? ar maybe the battery is flat and there is not enough charge to turn the starter?
A Flammable Plumber
most likely is ur battery .. check all ur connections , if that doesnt work just go to autozone and have them recharge it
yes if u hear a clicking thats ur starter solenoid working but there is not enough current to work the starter
fusable link
if you didn't unhook the battery before doing the work you may have shorted the system out and burned out the fusable link. I haven't done this on my BMW but I did it once on a Mitsubishi Gallant and it did the same thing. I called the dealer and talked to service tech and he told me about the fusable link and where to find it. I then went to Advance Auto Parts and spent about $3 on the part and went home, plugged it in and everything was OK.
check the bettery ^0^
Discussion Starter · #5 ·
Riped it all apart, checked all the connections....
And it was the battery... :thumbup:
If the car was not so bust flippin the xenons, i bet it would have had enough to muster up some energy to start...oh well..
Thanks for all the help anyway...
1 - 5 of 5 Posts
